turtle1173
- Nov 29, 2001
- 437
Hi all,<br /><br /> I took the carbs off of my 1972 85 HP for probably the 12th time today (literally in the past 3 months) to see if I can figure out what is wrong with them. The symptoms are: it will run full speed for about 1 1/2 minutes, then it will start missing. If I back down to around 1/3 - 1/2 throttle it runs fine. Any more than that and it starts missing. The motor is getting good spark and the compression is good. Timing is also dead on. It has New points, new fuel lines, & a new fuel pump. So that's why I feel it must be the carbs.<br /><br /> OK, I never knew that much about the main jet in a carb until I read TheMarineDoctor's post about what he encountered with the motor getting too much fuel and therefore performing at a lower RMP (I believe it was at 4400 instead of 5500, or something close to that).<br /><br /> I checked my manual and my motor is supposed to have .072 jets on the carbs at sea level (which is what I'm at). My jets are .064 for a difference of .008 on the small side.<br /><br /> If, in MarineDoctor's scenario, a difference of .004 too big made a motor perform over 1,000 RPM's too low, would .008 too small have the opposite effect and starve my motor for gas when I'm above 1/2 throttle???<br /><br />I would appreciate your input,<br /><br />Shane
