Re: high speed needle for 9.5?
You are not an idiot. There isn't one there. <br />If you look down at the squareish float chamber on the carb, down beneath where the low speed adjustment comes into the carb, you'll see a plug threaded into the casting. It looks kind of like a bolt. If you remove that plug, behind it is a fixed oriface that you can unscrew and replace with a larger/smaller one to compensate for altitude.<br /><br />Hope that explains it!
