I don't believe my '73 Baja w/'87 88hp has been equipped with a high-temp warning buzzer.(No gauges either.)I traced the tan wires from each head, and found an extra one on the left side with a rubber end on it. Each of the three wires tests as "hot" when the switch is on.(I did not test with motor running.) I was hesitant to intentionally ground a hot wire to test operation. Will I have to purchase a buzzer and add it? Thanks in advance.
