Re: higher pitch or larger diameter?
The problem with a sterndrive when selecting a prop is more blades are waisted technology. We can't (easily) change the drive heigth, so the extra blades add drag which equates to about an inch less pitch per blade to keep the same WOT RPM...the "only" RPM that matters..
So, as we drop pitch on a sterndrive, we might gain hole-shot, but top-end falls short.
The best bet on a sterndrive is to go with as close as you can get to the diameter of the 19, in a 21, which will likely be slightly less diameter, but that's for a reason.
We are starting to see alot of props on the market now that of the same model and design, are offered in a "normal" diameter, and a "large" diameter. The larger diameter in a sterndrive design will give better results over-all, "most" of the time.
