Re: hight of outboard??
OK, heres where the set back plays a big part. As yu go back you can also go up. A very general rule of thumb is for every 5" you go back (offset) you can go up 1". "Quite far back" usually means about 30" - 32" or so. Lets say that it's 30" back (easier on my math skills). For a good starting position you'll be looking for the AV plate, when parallel to the keel, to be about 6" up.<br /><br />Then we're back to the hull / prop relation. The more V, the higher you can run the prop, generally speaking. The more technology in the prop, the higher it likes it. <br /><br />And intended use. If you're always in fairly smooth water you can be on the higher side. If you go in rough water, especially in following seas, you'll fudge to the short side.
