Re: hinge pin removal
Similar to what marc c said
<br /><br />If your hinge pins have internal threads, you can thread a ¼ bolt/screw into the pin. Leave half an inch or more of the bolt hanging out of the pin. This will not pull the hinge pin out, but now you can use the bolt to pull/wiggle the pin out with a pair of pliers, your hands, or what have you. Like marc c said, make sure you have removed the nail, which holds the pin in similar to a cotter pin. I seem to remember using a ¼-20 bolt which is actually coarse thread. ¼-28 is fine thread. This procedure worked very well on a number of occasions on a 71 merc outdrive I used to have. From your description, it sounds like your 73 is the same. I am not familiar with the newer hinge pins, but from what I have read in this forum, I think those are the ones that require the hinge pin tool, or allen wrench.
