Hinge pin tool
eedwards
Is there anything i can use to remove the hinge pins from my outdrive besides the hinge pin tool?Only about $15, but i cant stand buying a tool just for one certain thing.
Re: Hinge pin tool
Ayuh,... A 1/2" allen key works Just as well, or Better...
eedwards
Re: Hinge pin tool
Nothing aggravates me more than a unitasker tool thanks.
YeboGogo
Re: Hinge pin tool
After breaking a few hinge pin tools I think Ill use the allen wrench in future.. Thanks for the tip
bomar76
Re: Hinge pin tool
Or, (posted for the umpteenth time lately and clearly defined in the FREE Mercruiser Factory Service Manuals)
Use heat (not a hairdryer, a propane torch) to release the Loctite that is used on the pins and they back right out.
Or keep breaking tools and skinning your knuckles.....
eedwards
Re: Hinge pin tool
I asked this question before i knew about the free manuals and found the other posting about.When stuff is under ADULTS ONLY why would anyone think thats what you are going to find there.Also i dont see anything here about using a hair dryer anywhere the was about the tool and that was it.At first thought you could not heat that area or you might melt something internally i saw that you can did it and they came off.And i was smart enough to use a torch and not a hair dryer.
Re: Hinge pin tool
Ayuh,... The Hairdryer thing is from another recent thread....
It takes 300?- 400? to soften the lock-tite...
The Adults Only is just a play on Human Nature....:D
eedwards
Re: Hinge pin tool
The first one i did i heated about five minutes and came right out with breaker and hex head.Now the other was a different story took about twice as much heating to get it out.Now that is done im going back to out boards;)
Dan F.
Re: Hinge pin tool
I made the tool from a U-joint strap bolt from an International tractor(truck). Welded a castle nut to the end to grab it with a 3/4" socket. Need one? Got plenty! :D
