hiring 15 $ an hour shade tree mechanics
bigbad4cyl
I have seen several people advertizing them selfs as certified this or that...living on boats at marinas and such ,,,,wanting to work on boats at 15 $ an hour or so....my question is have any of you had experiance with these types good or bad ...any advice besides suck it up and go pay 90 $ an hour
Sea Six
Re: hiring 15 $ an hour shade tree mechanics
Depends on what needs to be done.
cmyers_uk
Id be happy to go to them on personal recommendation Im sure there are bad ones and good ones its sorting them out thats the problem. Equally thought there are good and bad main dealers where you will pay $90 an hour but get a trainee doing the work or work done thats not required. So the best advice I can give is see whos used them and have a chat.
rodbolt
hello<br /> I still do a lot of mobile maint but I bill a bit more:) :) . also ask to see the marine general business insurance. if the are not insured stay away.<br />you will find if they burn it down,crash it whike testing or create more problems you will have ZERO recourse to collect any coins.
rodbolt
oh<br /> and the second good thing is people like me and DonS make a decent living correcting 15 doller an hour tech mistakes :) :) .
lakelivin
Rodbolt,<br /><br />what does marine general business insurance typically cover as far as a shops mistakes and subsequent damage?<br /><br />Don't know if you saw it, but I had an earlier thread describing how a shop filled my OMC outdrive from the drainplug, left it 24-28 oz short, and the gears/ bearings went.<br /><br />These are neighbors, and I tried to work something out, but did not reach a satisfctory conclusion. If their insurance would have covered this and they just refused to use it, I'm even more pi**ed than before. <br /><br />Actually, I'm really not pi**ed anymore, since from my perspective its turned from a personal issue (when I was trying to work something out) into a purely business one (small claims court in a couple of weeks). Now that that's clear, I feel like I can be amiable towards them personally, I just don't trust 'em from a business perspective and won't use the shop again. <br /><br />I'll prolly be reopening my original thread to get a little more input from this board before the court date...
Don S
It all depends on the type insurance, amount of coverage, what company etc. Just like any other insurance, there really is no "typical" marine insurance.<br /><br />Just remember on your small claims court thing, you are going to have to "Prove" he filled it improperly and that there just wasn't a leak somewhere that allowed the gear lube to leak out and cause the problem.
lakelivin
Don,<br /><br />Unless they out & out lie, I should be in good shape. The gears went within about 8 miles (and the next day) after bringing it home from servicing (no doubt about it, outdrive started screaming). The shop manager and mechanic came out within the next day or so to check it out. They heard it, immediately shut it down, and the manager asked the mech. if he had filled the drive from the bottom plug; the mech said 'yes'. Neither was aware that OMCs have a fill plug or of the air pocket issue when filling a Cobra using the drain plug. After topping the oil off (24-28 ozs or so) the screaming stopped but there was a whine from the outdrive that hadn't been there before. I called the shop owner with my concern, he came out & listened to it, but said it sounded normal to him. <br /><br />A year later the shop owner was still unaware of the Cobra fill plug. He knew (cause I showed him documentation) that you would cause an air pocket by filling from the drain plug, but apparently didn't read it very thoroughly 'cause he told me that unlike Mercs, you had to fill Cobras from the very top, let the oil settle and air escape, add more, let it settle, etc, etc.<br /><br />And although maybe it's technically possible that it leaked from somewhere else, odds are really slim. I checked the level a couple of months before taking it in, no problem, full. Then they changed the oil, the gears went the second time I drove it, and level was down 24 ozs or so when they checked a day or two after that. But it held at full level the rest of the summer after we added the 24 ozs it was short the day after I got it back from the shop.<br /><br />Should be interesting to see how it goes.
rodbolt
lakelivin<br /> dont go in there with the fill from the bottom theory. in 15 years or so of filling cobras I may have done two like the manual says. the rest I fill from the bottom.]<br />if you look at the desighn of the case its a modified v6 case. the area that the middle plug goes into is wide open at the top. I feel they just failed to fill it. it holds twice what an alpha will.<br />but I will warrenty that if it was me you were opposing I would have a case in court to show and explain to the judge.<br /> do you still have the old gears?<br /> to a professional witness with factory traing the gears will tell the story. if the are melted and blue you can be sure they ran with no oil. tear down your old lower sometime then post me back on the physics of air density fluid density and gravity and explain exacly where the air pocket will form.<br />most of the shops I have worked at have found the drain and fill procedures on cobras and some volvos to be to slow and to risky so we developed better methods. its one of the few times I will say the book is kinda wrong.<br /> and here in the salt pond if you dont have to remove the fastener then dont unless you know its been done recently. saves helicoils:)<br />I have a cousin that ran his 93 cobra for almost 10 years with the middle plug welded over cause he stripped it. he crabbed and floundered with it like that for almost 10 years.<br />start your original post back and tell us what ya got and what your trying to do. I have been a profesional witness in many cases in Va beach and Norfolk.
Lou C
I have heard that you can fill from the bottom, with the middle plug out, then when the oil starts to come out of the middle plug, put the plug in, replace the bottom plug, and then fill the rest of the way from the middle.<br />Bottom line is that they probably never read a Cobra service manual. I did mine 3 times the book way and never had a problem. First time I never had worked on a drive before. You have to make sure you get 2 qts in it. The key is to take your time, pump slowly, and don't try to do it on a cold day!<br />Now proving what they did or didn't do in court is another story. Like rodbolt says the gears would tell the tale.<br />What I don't get is why some people will not read the manual and realize they don't know everything. I have watched my nieghbor fix his Merc Alpha like that, and it almost cost him the boat (water inlet hose popped off, let water in the boat which was slipped). <br />I am not a marine mech, but all I did was read the manual and had no issues with doing it.
lakelivin
Originally posted by rodbolt:<br /> lakelivin<br /> dont go in there with the fill from the bottom theory. in 15 years or so of filling cobras I may have done two like the manual says. the rest I fill from the bottom.]<br />if you look at the desighn of the case its a modified v6 case. the area that the middle plug goes into is wide open at the top. I feel they just failed to fill it. it holds twice what an alpha will.<br />but I will warrenty that if it was me you were opposing I would have a case in court to show and explain to the judge.<br /> do you still have the old gears?<br /> to a professional witness with factory traing the gears will tell the story. if the are melted and blue you can be sure they ran with no oil. tear down your old lower sometime then post me back on the physics of air density fluid density and gravity and explain exacly where the air pocket will form.<br />most of the shops I have worked at have found the drain and fill procedures on cobras and some volvos to be to slow and to risky so we developed better methods. its one of the few times I will say the book is kinda wrong.<br /> and here in the salt pond if you dont have to remove the fastener then dont unless you know its been done recently. saves helicoils:)<br />I have a cousin that ran his 93 cobra for almost 10 years with the middle plug welded over cause he stripped it. he crabbed and floundered with it like that for almost 10 years.<br />start your original post back and tell us what ya got and what your trying to do. I have been a profesional witness in many cases in Va beach and Norfolk.
Rod, I'm gonna repost or reopen the original thread, but here's the link in case you're curious before that: <br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=008398#000000 <br /><br />In a way, I guess it doesn't really matter how they left the drive oil low, bottom line is that they did it and admitted it (I ran my summary of the issue in the first post of the above thread past the shop owner who did the service; he agreed that it was a fair and accurate summary).<br /><br />I believe it was an air pocket thing after reading the Cobra tips link from Stuart Hastings site. OMC told him that you were likely to develop an air pocket and fry the gears/ bearings if you filled a Cobra from the drain plug. I actually called OMC (Bombardier) a couple of months ago and talked to one of the older service reps familiar with Cobras; he said the same thing, fill a Cobra from the drain plug and you stand a good chance of creating an air pocket & frying the gears/ bearings. I don't know the mechanics of it, just that the advice came directly from OMC. I'm sure there's ways to fill from the bottom without causing trouble, but it's also documented that you can cause damage that way as well. <br /><br />I don't have the original gears, they sent the core back when they put in a rebult upper. I saw them and they were pretty torn up, but not black & melted. The (new) shop manager from the place that originally serviced it said the damage was probably from bearings that went and tore up the gears (but that it was purely coincidental that the bearings went immediately after they returned it about 25oz low on gear oil). Others on this forum have stated that one of the first things to look at to determine relationship between low oil level and gear damage would be the rear support bearing for the input shaft. My guess (and I do mean guess), is that those went & tore up the gears. Several wrenches on this site said they've seen gear damage from low oil level manifest itself in a number of different ways, i.e., the shot gears don't always look the same depending on what went first and how. <br /><br />I took it to a different shop this spring for service and they discovered the damage. They're OMC certified (original shop isn't) and the owner has been doing repair for over 20 years. He supplied me with a notarized statement that the drive damage was consistent with operating the drive with low gear oil. <br /><br />I'm hoping that expert corroboration, the fact that the shop returned the boat 25 oz low on gear oil, and that the damage occured immediately after they returned it low on oil, will provide a fairly compelling case. I can only see it as a positive using the fact that they admitted to filling the drive incorrectly (according to the manufacturer) and that there is documentation that filling it that way is likely to cause damage.
WillyBWright
My brother does that a little, but he's more into the carpentry end. Excellent work! He knows the guy that invented the tool-box in a bucket thing. The guy made one for himself and a customer saw it and helped him get it patented. He's filthy rich now and still a wharf rat last I heard.<br /><br />For jobs that require special tools, your $15/hr mechanic ain't gonna have em. He's going to throw the shims in that came out and leave it at that. There are good jobs for them and others that should be left to the dealers.
Buttanic
Just like everywhere there are good mechanics and bad. Doesn't matter if they do it for a living or hobby. Many times some of my friends have come to me after professonal shops have been unable to solve the problem and I find it was something really simple. I once had a professional mechanic tell me that a dual point distributor fires the plug twice, he didn't have a clue, but he had his own shop for 50 years. Just having tools doesn't make a mechanic.
John Carpenter
You may not appreciate my take on this, but here goes anyway. It all boils down to how much you value the shop owners friendship...because when you leave court you will have one less friend and no more money. He will lie in court. He is not your friend. I suspect that he is fully aware that his shop is responsible for the damage to your unit. If he were going to "do the right thing", he already would have. He is avoiding responsibility in front of you, and he will do the same thing in front of the judge. My good buddy lawyer would say that he is going to "testi-lie".<br /><br />Hope I'm wrong.<br /><br />Sorry...got confused about what thread I was in. This is in response to LakeLivin's problems with the OMC stern drive.
lakelivin
Relentless, <br /><br />No problem with your take on the issue, and you may well be right. But win or lose, I just feel like it's the right thing to do. I'm tired of people or companies that take advantage because they know that most of their victims won't aggressively stand up for themselves. <br /><br />As far as how much I value the shop owners friendship, right now I'm neutral. We had a civil conversation last summer and when we couldn't reach an agreement I told him that my only recourse was to let an independant arbitrator decide (small claims court being the only independant method I can think of). I specifically filed the case so it wouldn't come up during the holiday season as a courtesy to him and his family. If he's honest in court I can seperate the business from the personal and go forward from there. If he can't, so be it.<br /><br />If he lies in court, I'd just as soon know it and have as little as possible to do with him on a personal level anyways.
John Carpenter
I have to say that we look at this about the same way. Considering what you have been through, you have a pretty good attitude about the whole thing. Hope it works out for you.
lakelivin
Thanks Relentless,<br /><br />One other thing that might be of value (although not to me) with taking this to court, even if I lose: so far I've been pretty low key as far as mentioning this issue to others who live on the lake and might be customers (or potential ones) for this shop. <br /><br />As long as the owner is honest in court with respect to FACTS (things we've already agreed upon as far as what happened and when), win or lose I'll remain so and give him the benefit of a doubt so to speak (all things considered, a pretty generous gesture from my perspective). <br /><br />But if the guy out & out lies in court, any doubt disappears and I'll pass on my experience to anyone that might be interested in it. Not from a revenge motive (my business dealings with him will be over after this either way, and I see NO benefit in revenge), but rather from the perspective of at least warning others and perhaps sparing them a negative experience in the future. <br /><br />A lack of objectivity in others frustrates me, but it's a character defect I at least try to tolerate. But out & out dishonesty in order to benefit oneself infuriates me, and I'd want others who have experienced this in business to pass on that information to me so I can be on guard should I consider dealing with that person/ business down the road.
