TwoBallScrewBall
- Sep 14, 2003
- 1,695
The prop doesn't "unwind". There is a rubber bushing in the hub, and it is designed to slip and spin on an impact. The prop should stay on the boat, it will just be unable to push you since the rubber hub 'breaks'. <br /><br />Was there anything at all left on the prop shaft? Bolt? Pin? Prop Hub? If not, something wasn't secured properly, likely there was no cotter pin in the king nut.
