well coming in late evening with the sun glaring i missed the final buoy and took a turn into bad waters:facepalm:...doing no more than 10 mph I found myself in ~2 ft of water with smooth rock, hit the outdrive followed by an awful rattling/vibrating. I quickly threw it back no neutral but the noise continued...then i realized the drive must have kicked up from the impact and the ball gears were rattlin' away...promptly killed the engine, pushed myself into deep water and lifted the drive. Only damage is a good gouge on the back of the skeg, prop is untouched, I sure hope I didn't hit the hull but nothing was above water.
Powered up on the way home, seemed good, no other noises or vibrations. Should I check anything, How much damage did the ball gears take? I checked them before this season started and they were ~40% worn through, likely originals, most ive seen were far more worn than mine and still functioning.
Also, Im guessing the stringer is supposed to kick up upon unfortunate impact with the bottom of a lake? I know my neighbors merc alpha 1 did no such thing after he nearly tore his out drive clean off on a sunken log..
