Hitch Pin Hardness
alldodge
Don't remember when I drilled out the hole on the end of the hitch pin, but its been a lot of years. Drilled it out so I could put a master key lock thru the hole.
New truck has a class V receiver and my old class IV pin is a tad short. Bought a class V pin, looks the same (zinc plated) just longer. Break out the cobalt bits and going to drill the hole out. Ahhh no drill bit is bearly making a mark
Ideas
Outboard 200
I own a fabrication and repair shop and we do a lot of trailer repair and maintenance. We’ve found that the class V pins are extremely hard as they should be. We’ve started suggesting to our customers to go ahead and purchase a locking pin.
alldodge
Thanks, never found one of them I like. Usually cheap china junk.
Maybe get me a carbide bit
alldodge
Did some reading and found a guy that said he used a concrete bit an it work. I tried it and it does work, drilled right though. Need a larger bit to complete but just go slow and don't let bit get to hot
