So I have a 1989 Johnson 130hp Seahorse that I had the carbs cleaned, and serviced. As well as a new fuel pump put in about 2 months ago. Now it stalls under load when I put it in gear. It runs fine at top speed. But I have to rev it then put it in to gear to get it to go. I just found out that if I hold in the choke with my key it picks back up for long enough to advance the throttle to WOT, for which it runs fine . At lower speeds you can hear the enging bogging down until I push in the choke. Suggestions?
