inthedirtagain
- Aug 10, 2011
- 321
Went out on the water Saturday tubing and skiing with the family. The boat was in the water for a total of 5hrs, and was taking on water the whole time. When I pulled the boat out, my son noticed a good pee stream coming from the center of the boat. At first, I thought it was just the trailer draining water out of the center frame rail. When I looked underneath it, this is what I found:
This is a closed keel (no opening at the back), so I'm guessing that I took on a lot of water. I pulled the plug to drain everything once I got back to the house and the amount of water was astonishing. I didn't get a bucket underneath it, but it took over 30min to completely drain. Now that I think about it, the boat was acting more sluggish as the day wore on, and this would be a major contributor. Now I just have to seal it up and finish wiring up my bilge pump. It appears to be a missing rivet, because the hole is perfectly round. What do I need to seal this up? Can I use another rivet with silicon or 5200? If so, I have no idea how long it takes for 5200 to fully cure. Thanks for the help.
