Hole in water pump housing. Is this stock???
christians89
Hi all,
After running the boat on the muffs the other day I noticed a nice stream of water coming from under the water pump cover. So I took it off to find a nice pea stream of water shooting from the water pump housing. I shut the engine off and go in for a closer look, it looks as if some one has taken a small drill bit (like around 3/32) and bored a hole in my housing. It looks very stock. I have had the boat out on the lake like this and it doesn't run hot or anything. Ive also took the pump apart and all the components look to be in like new shape, other than this hole. I had thought about just covering the hole up with some jb weld, of course after proper preparation. Boat is first in sig, what do yall think?
jimbo_jwc
Ship Happens
Re: Hole in water pump housing. Is this stock???
Tell tail sign that water pump seal is bad . Also brg out try and move up and down by hand on pulley
bruceb58
Curious if you know what an OMC Cobra waterpump looks like.
To the OP...The hole is probably for the vent tube which you obviously don't have on there. Don't ask me why there needs to be a vent hose because I sure don't know.
Part #14
http://www.marineengine.com/parts/o...er=OMC+Stern+Drive&section=Upper+Gear+Housing
christians89
Bruce I believe you are right. I take it the vent is there just to bleed off excess pressure the system simply doesn't need, or to maybe allow the system to drain off while out of the water? I tried putting my finger over the hole and there wasn't much pressure behind the water, it was easy to seal off. If I recall correctly it never looked like a tube had ever been in place but I may be wrong.
bruceb58
Its been awhile since I had my cobra. Facing the drive is it on the lower left hand side of the housing?
bruceb58
Left side where that right angle nipple is?
christians89
Yep, somewhere along the line I guess someone had broken it off. Is there a check valve in the vent tube that may not allow water out?
bruceb58
No check valve. Not really sure what the tube is for actually.
christians89
Ok good to know. Ill just leave it be then. Thanks Bruce!
Lou C
No check valve, they all have a barb fitting there that attaches to a hose in the upper gear housing...
MRS
If water coming out the pee hole you are good to go. I have 86 cobra just changed my impeller and the water will squrt out 10ft. from the pee hole.
HCMQA
Yes it is normal.
If it has the right angle barb there is a drain hole of sorts that you can attach a hose to barb and put it in the drain hole to route the water down out of the bottom of the drive instead of out of the pump cover.
