Hole???
Highestgrade
I have this spot. Any advice how to repair?
oops!
Re: Hole???
its hard to tell if its a hole from those pics...it just looks black....
however...if it drips for a while.....its a hole....
if it does drip.....you have some water in the foam behind the area.
cheers
oops
Woodonglass
Re: Hole???
Have you tried poking it with a screwdriver to see if it has any softness? It so then it could possibly be a hole. If it is then you'll need to gain access to it from the inside and patch both the inside and outside and like OOPS says, check for any wet foam.
If it's hard then I'd say it's just gelcoat damage and a good grinding with a dremel tool and wash down with acetone and then filling with gelcoat paste would fix you up pretty quick.
ondarvr
Re: Hole???
It looks like air bubbles left from when it was built, you can use a marine filler or gel coat paste to fill them, or just leave them if they don't bother you.
Yacht Dr.
Re: Hole???
Air Voids in the strake and chines ..
And no .. do NOT repair them with gelpaste.. its too thick for this putty.
Use a Fiberglass filler.. then gel over it if you like.
YD.
ondarvr
Re: Hole???
They can be repaired using gel coat putty with very good results, if it's a large void it may need to be done (filled) in a couple of steps though, doing it all at once can result in it getting too warm, which can result in more shrink.
Woodonglass
Re: Hole???
You never did answer my question about whether or not the interior was hard or soft??
Highestgrade
Hard & green looking. The he is really small, I zoomed up on it alot, but still I would like to get it fixed. I am new to boats so I have alot to learn & I do appreciate all the help.
Woodonglass
Re: Hole???
Then I think you can either use a couple of layers of gelcoat paste or as YD suggested mix up some thickened resin with some fiberglass fibers in it and the brush on some gelcoat. Either way make sure and clean it out and wipe it down with acetone and then make your repairs. This will be a 1 hour job when you get ready to do it.
