Gizmobreaker
- Apr 26, 2008
- 45
I am rebuilding the carburetor from my 1985 15HP outboard. I keep it because it is the only motor that will fit through the cutout on the transom of my 1976 Catalina 27. While I was cleaning the body, I noticed little defects in the casting, in the floor of the chamber under the large removable plug. There are 3 drilled holes that are exposed by the throttle plate, but there are 2 smaller irregular holes that look like maybe there was air(?) in the casting.
The reason that I am rebuilding the carb is that I have a problem (of course). The engine starts fine and idles well, but not at very low revs. If I keep the revs up, the motor runs fine. However, if I am letting it warm up while I do other things, sometimes it stalls. Then I cannot restart for about 15 or 20 minutes. Either the motor has to cool down, or the engine is flooded; it's hard to tell which, with the motor on the back of the boat. Then is starts fine and I run the revs up and try not to idle. I have the side-mounted idle knob set at a very high setting and have always had to do that in the 8 years that I have owned the motor (and the boat). In fact, I have carved a little of the idle stop arm so that it can go farther than designed.
I run a 50:1 mix and the plugs are always dirty and a bit wet. Not soaked, but wet. I always disconnect the fuel hose and let the motor run out of gas. I keep it tipped when I am not on the boat. Even so, there is always a bit of fuel in the motor casing, under the carb.
I installed a new fuel pump, recently, plus a new hose and tank. Apparently, one should remember to only remove the 2 long screws when taking the fuel pump off while sitting in the dinghy behind the boat....
Are these holes a problem? I don't want to fill them with anything that might break off, later, and cause another issue. I thought about JB Weld but these are really tiny holes. Getting the epoxy into the holes would be a challenge. Something thinner would work but I don't know what would stay put.
I think that I have successfully uploaded 2 photos showing the holes. View attachment Carb Top a.pdf View attachment Carb Bore a.pdf
It's a bit hard to see the holes in the bore, but they are easy to see in the chamber on the carb top.
Thanks for any help you can provide.
