holeshot delay?..and also fuel sensor problems.
pudlejumper
ok first things first. the throttle delay.<br />if i gun it she speeds up but then all of a sudden gets a kick in the pants and runs like a top. seems to be the same time everytime i do it too. its a v4 140 evinrude.<br /><br />now for the gas gauge....its all wired up and i get no movement when the key turns on.i checked the grounds.re did the grounds,checked the lead wire,and then finally tested with a test light and the battery.<br />when i put the tester on the negative battery and lead sensor wire its throws it all the way past full violently.but the test light has no light.but from ground to lead wire W/tester it does nothing.<br />am i testing the wrong way?<br />PS i HATE electrical work.not my best subject.
pudlejumper
Re: holeshot delay?..and also fuel sensor problems.
just trying to bump it to the top,maybe ill get a reply pleaseeee? oh the year 1990,i forgot that part.
