holley 4175 merc 5.7
85well248
A few weeks ago I picked up a 85 wellcraft sportsman 248. Last owner didn't maintain. I replaced heads, cooling components, etc. I took it out for a test spin last night. The boat seemed a little sluggish, never been on one before though so not sure what to expect. After bringing it up to about 3000 rpm for a bit I tried for WOT. Nothing more than 3300. I only had a few minutes to test as I was watching lightning approach pretty quick. It didn't bog, stumble, miss or anything, just didn't have any more to give.
I began thinking it was the prop pitch, 19 right now. Then this morning I realized I really didn't hear the secondaries open at all, figured I should hear em a bit.
When on the trailer with the engine off if I place the controls full throttle I can move the secondaries with a screwdriver but they are very stiff/stuck. I know there is a spring in the AR but there is some play in the linkage and even where there is play they seem stiff.
I'm thinking they never opened. I ordered a holley renew kit but am wondering where the stick could be and if the kit will resolve it. Do these usually stick at the diaphram, or shaft?
Guess once I take it apart I'll find out but didn't know if there's other parts I might need to order.
Re: holley 4175 merc 5.7
Ayuh,... Mercruiser Never bolted a Holley on a Chevy V-motor,...
So,... It's hard to Say what's up...
mkast
The renew kit doesn't deal with the vacuum secondaries.
When you disassemble the carburetor, inspect the secondary linkage, apply vacuum to the port on the diaphragm port, if the linkage moves up you're ok.
You might want to look at Holley part number 125-500 Power Valve Check Ball. Depending on the year of the Holley you are using, one back fire, the power valve might/will blowout. After that, fuel will constantly leak from the valve, you'll be chasing an idle problem forever. Holley part number 717-7 throttle bracket, Mercruiser, it adapts the Holley carburetor to the Mercruiser throttle cable. There is also a chrome plate, looks like a big chrome four barrel gasket with a long extension on the rear so you can bolt the throttle bracket to it. I can't remember the part number. These parts are available from Summit
