Holley Gurus needed
calling all holley carb gurus
Finally splashed the boat this year. however due to budget constraints, I used the 715CFM Holley vac-secondary carb I had. Motor is a 468 BBC with Merlin heads, RPM air-gap intake, Stainless Exhaust with custom pipes
idles great, however needs more on the upper end, and being a single squirter, the hole shot would bog a bit when the secondaries opened if i mashed the throttle
so....fast forward after 30 hours and a few dozen splashes or so on the motor.....time to upgrade the carb.
ebay special, early gen 1 950 HP (date code 3186 - meaning November 13th, 1996) this is just before they went with changeable air bleeds
picked the carb up, discovered the secondary metering block was incorrect for a 4-corner idle carb and the throttle shafts and blades were butchered. mis-matched squirters and an odd staggering of main jets...... i called the guy up to get a refund or make it right. so after getting partial refund
2 new pro-comp billet metering blocks, a Holley /Quick fuel throttle shaft kit and new blades and I have the carb cleaned, painted, and back together
6.5 power valves, #80 jets on all 5 corners, stock emulsion jets in the pro-comp block
now, here is the issue
i can not get the carb to idle.
secondary air transfer slot is showing about .020", primary about .030
idle screws starting at 1 full turn out on all 4 corners
adjusting the 4 screws did nothing
motor will run 2000 rpm or higher, however will not run on the idle circuit
if I sit there with my finger on the accelerator pump and tweek the pump just a bit, i can get it to idle. that tells me its not pulling fuel from the idle circuits
if I put my fingers just above the air bleeds on the throttle horn, I can get the motor to idle.
that tells me that either the pro-comp metering blocks have an issue, maybe with the IFR jets, or there is something else wrong.
the outer 4 air bleeds measure stock at 0.070"
any suggestions?
for the record, not my first holley, however the first one that has me stumped
Talked to holley's tech line for a while. the guy said start by restricting the LSAB's since my carb is an early HP, that means epoxying the holes shut and re-drilling (or drill and tap for changeable jets). he suggested going down from the .072 that are supposed to be in there to closer to .040 or .050.
then open the throttle plate bypass just a bit.
So talking to a few of my gearhead friend, they suggested looking at the IFR's. they speculated the IFR on the speedmaster block was way way too small. this is something where very minute changes effect the idle AFR in a serious swing. the Speedmaster/PCE metering block has only .0225" orifices on the emulsion tubes and the IFR. at a minimum the IFR needs to be at least .031 per the Holley and Demon documentation I have, preferably closer to .035" at .0225, that is only .0004 square inches vs .0010 square inches. that means they are only 40% of the size they need to be. no way the stock Speedmaster metering blocks will support more than a V6 at idle with stock IFR jetting they have in the blocks. Talked to the folks at Speedmaster in Cali twice, may as well call my local politician. the block itself may be usable, however the block assembly is a joke and there is no support from Speedmaster/PCE. they simply know nothing, and will not return calls
Drilled out the main body LSAB's and HSAB's and threaded for #10-32 standard air bleed jets. however local speed shop did not have any stock on the emulsion jets or air bleeds, so off to the hardware store in the AM to buy some screws to modify. will most likely get brass set screws and drill with the pin-vise in the AM
will attempt to drill out the Speedmaster jets and see where that goes, Will also pick up a few #6-32 screws. going to mimic the Race Demon setup for an 850 on the IFR and emulsion tube jets. however if that doesnt work, I already found a replacement stock 950HP rear metering block
Will report back when I get the carb back together. the new main body gaskets finally showed up.
awaiting air bleeds and IFR/emulsion jets from Summit
new pin drill and pin vise showed up...... was supposed to ship from Orlando (2 day by mail tops). shipped from New Jersey and took 9 days to get here.
closing the loop on this
order from Summit finally showed up on Friday. removed all the speedmaster/PCE jets
starting with the IFR, changing from the .0225" to .033"
changed the VPCR's from the .0225 to .059
changed the e-jets from all .0225" to
E1 - .035
E2 - blocked
E3 - .033"
E4 - blocked
Ef - .031"
HSAB's at .032
LSAB's at .059
bolted the carb on, and after priming the fuel system, turned the key and it was idling at 800 RPM
adjusted the 4 corners, and it will idle down to about 700. ended up going to .061" on the LSAB's just to lean out a bit more
now, to drop it in the water to load it after i get the tree up and the outdoor lights up per the Admiral.
