ehenry
- Jan 6, 2002
- 2,393
I have a Trane central heat/air conditioning system in my house. When the a/c sytem is on the compressor unit out side comes on and runs fine but the inside blowing unit will not run. Same for the heating side of the system. It is a gas heating system. When the thermostat is turned to heat the burners in the system light and burn fine but the blower unit does not come on. There is a flashing LED on the inside of the unit along with a list of the codes. The LED is flashing slow and steady while system is set for A/C. The list says this is "Normal No Call For Heat'. If I switch the system to heat it flashes steady and fast the list says "Normal No Call for Cool".
Any ideas??
Any ideas??
