home made guide posts
mcarlito
Hello,<br />I'm looking for information on how to build homemade side guide posts for my boat trailer. The boat is a 14'-0" Crestliner. Does anyone know of a link that might have a set of plans??<br /><br />Thank you<br />Mike and son Zach
dajohnson53
Re: home made guide posts
I made a set after looking at 'store bought' ones. <br /><br />The upright part is just ABS pipe. This is what the 'store bought' pipes often are. I use the heaviest, strongest black ones, I think it's 4 inch ID. A lot of commercial ones use white pipe with regular old ABS pipe end caps. <br /><br />I have a pretty heavy 21X6 foot welded aluminum river boat with a big V6 outboard. It's amazing to me the stress these ABS pipes will take when loading in a swift current and/or wind. <br /><br />The pipe slips over a metal bracket. They are a piece of 1 - 1.5 inch galvanized channel material (I'm thinking - not at home to actually look at mine) that are hollow, square cross section, about a foot or two on each dimension. The bend is not 90 degrees - angled to approximate the angle of the hull. I've seen some that are welded to this angle, but most I've seen are bent.<br /><br />The horizontal leg of the bracket gets attached to the trailer frame with appropriate sized square U-bolts and fittings. They can be slid in and out to adjust for the width of the boat. They can be put above or below the trailer frame depending on need.<br /><br />If you can imagine or look at the brackets that are used for side bunk-style guide-ons - the type of ABS guide-on I'm talking about uses exactly the same bracket. I discovered this looking at a set at the local boat shop - they were exactly like my commercially made side bunk brackets.<br /><br />In fact, rather than fabricating, I just bought two of these side bunk brackets and U-bolts from a local boat shop. That way all the drilled holes, etc. are fully galvanized, which the local fabricating shop couldn't do anyway, and I didn't have to hunt up the U Bolts.<br /><br />The ABS pipe slips over the vertical leg of the bracket. The diameter of the pipe is selected to slide over the bracket and loose enough to be able to rotate. length is cut to accomidate the height of the gunwales, when the trailer is submerged. So they'll be higher than the gunwales. Cut it long, you can always cut it down after you figure out what works for your boat and typical loading scenario. They are capped a the top end, but you need air holes in them so they don't fill with air and float off the bracket/post when submerged.<br /><br />Hope this helps.
imported_Warren
Mike.....Heres a pic of what I ended up doing....<br /><br /> I wasted $80 for the "One Size Fits All" side bunk kit for my boat and it didn't fit....Those things are made for the standard 3" or larger tube trailers.....<br /><br /> This one cost me about the same amount after paying the welder but I have no problem launching in the Pacific by myself when the tides rippin......Warren
<br /><br /> The brown primered pieces are what I added....I put in an extra crossmember to stiffen it up a little.....Sorry about the pic size....Hope this helps......<br /><br />notice the 12 footer suspending in the background by one motorcycle strap :( ....At least I took the outboard off
BigPoppaG
That looks pretty good.<br /><br />Looks like the fender needs a little TLC. ;)
RobG
I used some 3/4" galvanized electrical conduit, bent it to a nice angle and slipped a piece of 1 and 1/4" pvc over each end. To attach it to the frame, use the galvanized uni-strut you can get at home depot for pipe hanging and just a piece about 12 to 16 inches per side (might depend on you boat width) use 2 u-bolts to fasten the whole assembly to your trailer and adjust the guides. Everything cost about 30.00 bucks, but I made guides for 3 of my trailers. I'll try post the pictures. They hold firm even after slamming into them a few times when a storm brewed up over Lake Fork.
Mark42
Rob,<br /><br />What is uni-strut? This sounds like something I would like to see and copy. Please do post the pic.<br /><br />Thanks,<br /><br />Mark
Warren,...... Do you think you could Resize that photo ?????<br /><br />This is how I built Mine....<br /><br />It's Mostly Aluminum scraps,+ a couple pc.s of PVC..........<br />
<br /><br />The Aluminum angle pc. is screwed to the side of the trailer frame,.. <br />This allows some Give action to the side loads......<br />A pc. of 1 1/4" tubing welded to it,+ the 2" tube with the turn-outs on top, is slid down over it,... <br /><br />the little short pc.s of 2 1/2" PVC are at the bottom, where the hull touches them.........<br /><br />The Centering Force required to center the boat is provided by 4 Bungee cords down near the bottom of the guides.............
rwidman
Originally posted by Mark42:<br /> Rob,<br /><br />What is uni-strut? This sounds like something I would like to see and copy. Please do post the pic.<br /><br />Thanks,<br /><br />Mark
Unistrut is a "U" shaped channel with holes punched every inch or so. It's commonly used by electricians to suspend conduit in commercial construction. Your local electrical supply house will have it. It's not expensive.<br /><br />
mcarlito
I want to thank everyone for all the input. I'm going to build a set using a uni-strut (bolted onto the frame) with a welded piece of steel that has a 3/8" hole in it. I'm going to attach a piece of threaded rod into the hole and over that put the PVC pipe on it. Hope it works.
