scipper77
- Sep 30, 2008
- 2,106
Fellow AV Geeks, I have a question.
Here's the setup...
I'm Putting up crown moulding to hide my speaker wires for my 5.1 surround sound system. I lowered the surround (rear) speakers to be 2 feet above seated ear level and what a difference it made. They were up near the ceiling before. I did the reading and learned that the front speakers should be at ear level and rears slightly above.
After I finish putting up the crown I will not be able to change the length of the wires to the speakers so I need to get the speaker placement right before I can finish putting up the crown.
What I specifically am looking for is a good audio file that I can use to check my setup before I make my speaker locations permanent. The DVD's and blurays I have would require a good amount of searching to find the things I am looking to test.
When properly set up, sounds that travel left to right and front to back need to sound like they are moving around the room and not like they are jumping from one speaker to the next.
My blu-ray player is integrated with the surround sound (boxed setup) and will accept audio files on a memory stick. Additionally I can burn to CD or DVD.
Can anyone point me to a good test track/file I can use for setup purposes?
Advice is also welcome.
Here's the setup...
