Homemade Shift Cable Mount Bracket?
chrisf695
I am kinda in a pinch right and cannot get the acutal brackets for the shifter and my ignition in time for this weekend... So what I thought is I could just use a thin piece of aluminum and just cut it small and make the cut out holes that are required and use that for the time being... Would this work for now? Figure its easy fix for now...
What I'm trying to make...
http://www.imcomarine.com/cal_store/...n-bracket.html
foodfisher
Re: Homemade Shift Cable Mount Bracket?
Couldn't access the link. The only thing that came to my mind is aluminum draws current. Be wary.
I tried that link as well, it definitely doesn't work. Without a picture or mechanical drawing I'm really at a loss to figure out what you're trying to do.
