Re: Honda 225 HP 2007 oxygen sensors
I would HIGHLY reccomend taking it the dealer and seeing what other codes its throwing on diagnostics software - sometimes the IAC (idle air control) valve being bad can inturn cause your 02 sensor to go repeatedly - i mean sometimes as much as every 10-20 hours. The 02 sensors are ridiculously sensitive to mixtures being thrown off.
Other than that its pretty normal them to go around 400-500 hours.
O2 sensors are kind of just something that goes bad on those unfortunatly - but you can save yourself ALOT of time and money buying or making the special torque socket and repairing yourself - labor costs are ridiculos and its already a 100.00 part
, there was an tech change for the oil pan gasket and exhuast pipes for a2-a5 engines which should only be early 2005 and before 225's - but that was mainly for causing oputboard engine fires and catastrophic failures due to water getting sucked up. The 02 sensor will likely go bad as a result too but you'd be seeing alot of other problems pop up aswell.
Good luck! !
Just incase heres the affected serial numbers for the SB ZZZZ was talkin about.
BAGJ 1000001 ~ 1500324
BAHJ 1000001 ~ 1500022
