I have a strange question...<br /><br />My current setup allows the engine to run right at the redline when the boat is lightly loaded. (normal load drops the rpms about 100 or so) We put in a new set of plugs the other day as routine maintenance and have since put about 10 or so hours on them. We pulled them out tonight and found that they appear to be pretty burnt looking. Definitely not normal.<br /><br />My question... could the high RPM be burning the plugs up? The engine is otherwise running great. (I am in the process of changing the prop out to bring the RPM's down a bit)<br /><br />Has anyone ever seen this before? Should I swith to a colder running plug?<br /><br />Nav
