Honda 9.9 4-stroke accessory 12V socket problem
makassiouk
I stuck the multimeter set up for voltage into the accessory output on my motor and found no uncle Electricity living there. Went up the cirquit with the same instrument and found nothing further up either (passed fuse and a couple of connectors).
There's a device (regulator) with a biggish heat sink on it - from that one 12V should be output, no? I have no idea how to test further...
If I rev the motor up, I see voltage climbing from 0.00 to 0.06-0.07. Is there an explanation for this?
1. Is the measurement device wrong for this task (something to do with impulse power sources comes to mind)
2. Does being or not being in gear matter?
3. What do I do next?
makassiouk
Re: Honda 9.9 4-stroke accessory 12V socket problem
And when I say "accessory socket" I mean the 12V output on the motor which is supposed to charge the external battery.
isaksp00
When I attach my multimeter to the 12V output plug on my Honda 8Hp (BF8A) I get a 12V DC reading. I also attached it in series on the DC amps setting, hooked to a battery, and can see the amps increase as I rev up the engine. Can't help you with what might be wrong in your case, though.
pvanv
1. Probably
2. No
3. Check to see if you have A/C feeding the rectifier. If so, you probably need a new rectifier. If not, the alternator (under the flywheel) is probably failing.
makassiouk
Aha. Ok, thank you! What is the range of AC voltage that is supposed to get to the rectifier, then?
pvanv
Depends if you are measuring peak-to-peak or RMS. From my EE days... Figure approximately the square root of 2 times the output DC. So probably about 20 v PP.
makassiouk
Thanks a lot, man. I'll keep looking :)
