Honda B100L Water Pump Impeller
Ebower
Hello all,
I just purchased a Honda B100L and it does not pump water, so I need to buy Water Pump and Impeller Repair Kit. Ayone know which OEM part number this is or which part number from iboats it is? I call iboats and also checked on line, but they said that the do not carry this kit, which I can't believe. Any imput would be appreciated. Thanks.
cp
Re: Honda B100L Water Pump Impeller
Go to this link to see Honda water pump service kits: http://marine.honda.com/pdf/accessories/ml.rerap45a.MAC_Water_Pump.pdf
But, I don't see the model you wrote among those shown, so you may need to contact them for more info:
Tel: 770-497-6400
Fax: 678-339-2519
Monday - Friday 8.30 to 5.00 EST
Before you go $pend a bunch of money though, how do you know it's not pumping water? If you're judging by there being no flow out the pee hole, it could just be that the pee hole is plugged. It would be unusual for the water pump to totally fail to the point where there is absolutely zero water flow, but if you're sure, then $pend away. Good luck.
