Honda BF50 Lower End Removal
Mac26Sailor
I have removed lower ends of other makes wioth no problem. I removed the 4 main bolts from above the anti-cavitation plate, removed the anode and the deep set bolt that was under it. I can pull the lower end down about 3 inches and then it gets stuck. It is a 2006. Any suggestions?
pvanv
Re: Honda BF50 Lower End Removal
Disconnect the shift rod.
