sandiegofisher
- Sep 8, 2002
- 11
Just got my Honda BF75 (7.5 hp?), 4-stroke with CDI ignition put together. (Serial number above 7100001.) It was given to me in pieces because of a bad lower unit seal. After replacing the seal I got it to start on the first crank. I was busy adjusting the idle speed when I noticed a steady fuel leak comming from the the breather valve body where it connects to the starter case. If anything leaks here it should be oil, right? Upon checking the crankcase oil dipstick I discovered that it was nearly pure fuel. What would cause this problem? I will drain the crankcase tomarrow and replace with fresh 10-40 oil. Then try again. The motor had been taken apart about 4 years ago by a young boy who gave up when it became too difficult. Fortunately he did'nt take apart the power head. It took me about a week to put it back together and another year to figure out the CDI wiring (no manual)! I don't know how many hours the original owner put on it but it looks as though it got regular use. I'm sure it's gone through it's break-in peroid and then some. Do the rings need a chance to re-seat perhaps? If I change the oil regularly and run it, will it be OK and not cause damage to the motor or blow up? This is my first experience with outboard operation and repair. Any help or suggestions on what I should do and what might be causing the problem would be greatly appreciated. Thank You, Chris
