Honda Part Identification
gobirds82
Hey Folks, I was looking for some assistance identifying a part by name or number. I have a 30 hp Honda (BF30A) from around 2000, I bought it used last fall. The motor needs to be manually moved into the different position from tilt and run. While towing it in the tilt position, it bounced around and the pins on the spring loaded bracket sheared off. It is a U shaped bracket. Can anyone identify the name or the number of the part(s) needing to be replaced? THanks.
http://www.iboats.com/Swivel-Case/dm/cart_id.621130973--session_id.458450230--view_id.1326044
Alumarine
Welcome, sorry I can't answer your question but when you get it fixed it's possible that if you leave it in reverse while towing it won't bounce around.
