Hi, I've changed my inflatable to a 3.8m Honwave airfloor, and want to use my Johnson 9.9/15 hp 2 stroke on it, I've hit a small problem with the transom height - the clamp to cavitation plate on the Johnson is 17.5 inches, and the standard height of the Honwave transom is 16 inches in the middle, although it sweeps back up to meet the sponsons at about 17.5 inches at each side - in other words the centre of the transom drops down by 1.5 inches.
I can get maybe 1/2 inch by lifting the transom clamp up as hitch as the pad will let me, but really I need to extend the transom back up to give me the optimum height for the cavitation plate in relation to the keel. Anyone got ideas for how this might be done? Sandwich the transom between two sheets of plywood and put a stringer in the gap?
Plan B is to run it with the motor deeper than it should be!
Thanks in advance!
Thanks in advance!
