I have a 205 Bayliner Capri. 5 Litre 220hp, 305. I have had issues in past starting the boat. Very often it would just click when trying to start. I would clean battery
posts and then it would work. Cleaning the posts never worked this time so I thought I would just try a different battery. Well I hooked it up wrong and had smoke
coming from some of the wires. I checked all fuses under the steering column and they are all fine. I had to replace fuse to radio. Are there any other fuses hidden
in or around the motor I could check before checking the rest. Without taking things apart what is the best way to check alternator, starter, solenoid or whatever else
I may have damaged. With some help I feel I can fix this myself without having to take it in. Would like to hear from someone who has knowledge in this.
