Horizon Express 1000W Windless Bearing Cross Over P/N's
pmcs
Hey Folks,
I thought I would share for others who are rebuilding this Windless. It was discontinued in 2003 and the bearings are hard to get. Below is the info for replacing all bearings, including in the $500.00 Electrical Motor bearings.
CrossoverBearing NumberOEM P/NRough O.D.Rough I.D.Rough HeightRough O.D.Rough I.D.Rough Height
HK15122560531250.80.60.46320.3215.2411.7602
HK20162652020-0321.0230.7840.63525.984219.913616.129
HK251627531-0271.250.990.6331.7525.14616.002
HK301228531-0281.4591.180.46637.058629.97211.8364
HF30202960531291.461.180.78237.08429.97219.8628
R530407 (Gaco)30531-0301.51.1838.129.9720
INCHESMILLIMETERS
Motor BearingsBack(by Brushes)6001LU28128
Front (gear)6202LU351511
dingbat
Not that it really matters, but the bearings listed are metric.
Appears someone measured the bearings in inches then tried to convert to metric, thus the weird metric diameters. IE not whole numbers
Actual, HF3020 - 38 x 30 x 20 (1.496" x 1.181" x 0.787")
HF3020 - 38.1 x 29.972 x 19.860 (1.460" x 1.180" x 0.782")
The errors don't look large, but they're huge considering typical bearing tolerance runs plus and minus 0.0005"
pmcs
Yep, I mic'ed them and wrote down the rough measurements. I ended up getting the actual P/N off the bearing I removed, that is what is listed as cross over P/N:
pmcs
Hey Folks,
INCHESMILLIMETERS
IMPORTANT !!! There is a bearing (#29) that is a clutch bearing. Make sure you install it with the arrow pointing Clockwise !!!! Also, make sure you install the Mainshaft space, #18. Just found it on the bench after assembling the windlass and painting it. Now I have to disassemble it again and install. Also, The 2nd Compound Gear assemble is a high failure item. I thought it was a solid gear, but it actually has a moving sleeve that pushes the smaller gear and allows clutch dogs inside to engage or disengage depending on the direction it turns inside the clutch bearing(#29). This video is for a different model windlass, but is very similar to this model. The guy does a good job explaining the repair of the 2nd compound gear:
