Horsepower
ebrich2
I need to ask a question that I'm sure has been asked before.
i have a 1988 ranger 374v that I'm thinking of putting a new motor on, it's rated for a 175, could I get away with a 200? Thanks!
tpenfield
You should be able to make a faster get-away with the 200 HP instead of the 175 :)
roscoe
It depends what state /country you live in?
In some states, it is actually illegal to overpower a boat.
you are in GA, so read your regs, or contact the dir or whoever patrols the waters.
you can get away with anything....until something happens and you get caught...
either caught by the local LEO because your over-powered
caught because you over-powered your boat and ripped the transom off
caught because you were involved in an incident and they find your boat was over powered
you wont find anyone that says its ok to over-power your boat.
jimmbo
As mentioned earlier, it depends where you live. I know in Canada, it is not illegal to exceed the 'recommended' max HP. Insurance companies may balk, but if it is stated in the policy that the engine is bigger and they accept your money, they would have a hard time denying coverage later.
33 yrs ago I remember a guy trying to buy a used 225 V6 Mercury to install on a Vanguard Banshee(a flip of the Glastron GT150. James Bond jump boat) Which was rated for 90hp. My dealer, when he found out what the guy wanted it for, refused to sell it to him. A couple of days later, a call came from another dealer who wanted the engine wholesaled to him. Sue enough the guy found someone willing to sell it, but refused to install it. The GT150s and flips, were often seen with 115s, 135s, 140s, and inline 150s. they were scary to drive with the 3 biggest engines.
Myself had an 15 Invader, a Flip of the Crestliner Cruisader 550. It was rated at 90, I test drove it with a 90 Merc and then bought the same boat from the dealer with a 140 Evinrude. Later, I aquired a Crestliner Cruisader 550, I removed the crank rated Merc 90 that came on it, and replaced it with prop rated Merc 115. My underwriter was aware of the swap and never had a concern.
ebrich2
thanks for your input guys, I was just wondering if it would be possible.
I wasn't necessarily looking to break any speed records or anything but my ranger can hit between 50-55 with an 88 150 black max that is desperately in need of replacement but the boat is rated for a 175 so I was curious about going 1 step further lol, also is it feasible to put a brand new motor on that old of a boat thanks again.
PB48052
If there isn't a big weight difference in the motors, a 25hp increase will probably still be manageable if driven with proper cautions. I did a swap like that before, long story and many years ago
jimmbo
In the late 70s, early 80s, the 200/225 was lighter than the 175/150 engine, even though they had more displacement. In those engines the 122 in block had cast iron liners, while the 142 in block was the same casting without the cast iron liners. but had Chrome plated bores instead
