Hose part number
bijou22
I am trying to find out the part number for the sea water intake hose that connects to the water pump of the engine on a VP 4.3GL 1997 which has a Cobra SX leg?
I want to buy one as a spare in case anything should go wrong with the Perko flush valve I have installed, so I can simply replace the cut hose.
Don S
Re: Hose part number
OK, it's a 4.3 GL, Is it raw or fresh water cooled and do you have a power steering cooler or not?
If I remember correctly, it's an LK model....... right? ? ? ?
bijou22
Its a 4.3GL PLKD thats raw water cooled, it does have power steering but not sure about whether or not it has a cooler.
Hope this helps.
Don S
The PS oil cooler is on the back of the the engine, if you have PS, it has a cooler.
The Hose is 3852282 from the pump to the cooler. If by some chance you don't have PS and have Hydraulic steering system and no PS cooler, then the hose PN would be 3855678.
