Chickenbone
- Sep 3, 2013
- 14
Hey guys. Need a hand here. First boat, still learning. Bought an '88 OMC 4.3L V6 on 17ft Sunbird. Guy I bought it from had an overheat that melted the left breather hose to the flame arrestor. Apparently the manifold got really hot. Anyway, I changed the impeller, flushed all the water passageways and put it on muffs. Engine ran fine for 30 minutes, no problems.
Put it on the lake and it overheated at idle and low rpms. On a plane the temp quickly came down to normal. So we basically just cruised around for about a hour and enjoyed the ride. We decided to stop and turn off the engine for a few. I noticed a water-running sound from the engine. Tried to start it back, and it seemed to be seized. Had to be towed.
Back home, pulled plugs and got water from 3 and 6. (closest to stern?) I have not checked the flappers, but optimisticly hoping that they have melted and allowed some water into the cylinders. I got all the water out, and have spayed penetrene into the cylinders. Have not tried to start the engine with the starter, and not sure of the best tools to spin the harmonic balancer by hand. Don't want to break a bolt by using a wrench. Is there a standard procedure for troubleshooting this? And do the exhaust Manifolds have to removed to get to the flappers?
I know this is a common issue, but since it occurred right after an overheat (still diagnosing that problem too) I'm hopeful I could still not have to break out another thousand. Thanks!
