hot buzzer comes on while at idle
indypopeye
1988, Force, 125hp<br />Does not put out a very good stream of cooling water while at idle. More like spitting than peeing. And then the hot buzzer will come on. If I take off and run , the buzzer will go right off and stay off while running.This just happens at idle. Thanks <br />Tom<br />Indypopeye
revertmastec
Re: hot buzzer comes on while at idle
Sounds like it is time to change the impeller.
Safevet
Very easy fix - replace the impeller dont keep running it like that as it will damage your engine.
indypopeye
Thanks for this info.<br />Can you point me to the impellor location,in the force, 125, 1988 model?<br />tom<br />indypopeye
scotiany
While you're changing the impeller, check the inside surface of the impeller housing. Make sure it's smooth so that you won't be replacing the impeller again prematurely. Also lightly grease the inside surface.
revertmastec
You have to drop the lower unit to access the water impeller. Get yourself a manual before doing this. The first time may take you a couple of hours but after that will onlt take about 30min. When you have a manual give us a post if you need help.
