hot water coming from pep hole
jamesg1972
the water coming out my pep hole is very hot. the heads are hot to the touch also. does this mean the water pump needs to be replaced. my motor isa 86 150
verado7
Re: hot water coming from pep hole
if its hot that you cant stand to keep your hand under the water then yes - but the water will be fairly warm when running on the ear muffs - is the stream good ? if the head is getting hot to where it burns yo could have some crud clogging up in there - carefully remove the water jacket bolts and check it out in that case - more outboards are killed by overheating than anything else - and i've seen enough thru my buddys shop to know - also its a good idea to get a temp guage for it .
