Hey all I have a 1995 Volvo/OMC 5.0L Fuel injection with an sx drive. The boat has a shower hooked up to the port side block drain for hot water and an in-line pump after the mixing valve. Problem is I don’t seem to get enough hot water to run the shower on full hot even with the inline pump running. It sprays good for a second but then seems to run out of water. I bought the boat used so Ive done some replacing of parts as well as trying to flush out the block/manifold and risers. Recently I circulated rydlyme through the motor for 4 hours to try and rid the motor of deposits and rust. But still it doesn’t seem to have enough to keep up for the shower. I’ve replaced the raw water pump and the water pump this year so I know they aren’t at play here. After this long winded story..questions are 1) is this normal to run out of water like this immediately? Or is there a blockage or something else? 2) can I install a tee and hook both block drains (port and starboard) up to the shower to try and get a steadier supply of water?
boat doesn’t run hot, manifolds usually cool to the touch. Any help is appreciated! Thanks all!
