hot water draining from pee hole
Redfish99
When I turn my engine off after flushing it with fresh water in a tub the remaining water that drains out through the pee hole is really hot. Is that normal? The water is just a little warm when it is peeing with the engine on.
Grub54891
When running, the cooler water blends with the hot water to help cool the exhaust, When shut down, outboards are self draining, so the water in the block is hotter. As it drains I'd imagine it would feel hotter with the water from the block itself. I've never checked the draining water myself, but yes it sounds normal.
5150abf
I have a 2018 4 stroke and the water out of the hole is scalding hot when it drains so I would think it is normal.
Grub explains it very well.
