- Mar 8, 2009
- 42,672
Lets discuss HWH and maintenance
Going to replace the HWH again, and main reason is its about 12 years old and I want to.
Have a GE hybrid in the house and standard electric vacation house (replacing this one)
Been doing some more reading and should probably have replaced the anode, but never have in any of them. Says to check them every 2 years and replace when needed (3 to 5 years). Most anodes are aluminum but magnesium is said to be better an will also not put aluminum in the water we drink.
I flush the tank every so many years if I think about it (not very often), I connect a hose to the drain and let the hot water pour out of it for maybe 5 minutes into a nearby drain. The wright ups on the net says to shut power off, close cold water valve, open hot water valve in tube or sink, and then let it drain until clear. Why shut everything down when you can just open the valve and let it go?
Paid high dollar for the hybrid but it only has a 10 year warranty. Would need to remove the covers on top to even get at the anodes, but figure I should do that.
All the water heaters last about as long except the Rheem marathon because the tank is not steel.
