Hour Meter
Parkerosa
We have just purchased our first boat. The hour meter is constantly clicking away when the key is in the ignition. Should it only be working when the motor is actually running?
rickdb1boat
Re: Hour Meter
Kay, <br /><br />OK, I give up. What is an "Air Meter"? Or are you referring to an "Amp" Meter? More info please.<br /><br />Rick
Trent
Re: Hour Meter
Air meter?? Describe a little more what your talking about? Never heard of an air meter??
BigBabyLou
Re: Hour Meter
Kay, are you talking about HOUR METER? I would guess so based on your description.<br /><br />And the answer is: the hour meter should run with the ignition key in On/Run position.<br /><br />Happy boating<br />Lou
Parkerosa
Re: Hour Meter
It is really the hour meter(air) it is clicking the entire time the battery is connected - even if the ignition is not on.
Solittle
Re: Hour Meter
Should be pretty easy to hit Radio Shack and pick-up a toggle switch.
Bob_VT
Re: Hour Meter
You can either rewire the meter to the hot side of the key switch or install a battery cut out switch.<br /><br />The meter should only run with the key on. If you want to listen to a radio/cassette/cd then put that on an independant switch. Leaving a key on w/o the motor running can (slowly) burn your ignition system up.<br /><br />Bob
Skinnywater
Re: Hour Meter
Hello Kay,<br />I recently installed an hour(fun)meter on my new boat.<br />The meter should only operate in run postion of the key. <br />If your boat is new, the dealer improperly rigged it and they should correct it for you.<br />If you are mechanically inclined, there may be multiple wires to choose from. For instance, if your gauges are lit when the key is in run position you can jump off of that wire. However, a simple continuety check can be done with a test light/ volt meter for the proper wire.
Re: Hour Meter
sounds to me that the "hot" wire for the hour meter is hook up to the incoming "hot" wire on the ("BATT" terminal) ignition switch....should be hooked to the "IGN" terminal on the back of the key switch... the other wire on the hour meter goes to ground.....
