Re: Hours of Engine useage!!
The corrotion from salt water varys with the temperature and the amount of salt in the water. I have seen 10 year old engines corroded into scrap, and I have seen my 1984 115 HP without any traces of corrosion. The question is probably wether the boat has been in the sea all season or if it has rested on a trailer when not in use. When the boat is in the sea all season, the engine is better off with more hours on it because it will corrode more when not running. Do as studlymandingo says, and also check the wiring visually for corroded wires and connectors. And of course - if the motor looks like scrap, the maintainance would probably be equal.<br /><br />-M-
