How are the cheap props here on iboats?
Fordiesel69
Looking at the Solas brand prop on here for slightly under $100. Any good by chance? What are the disadvantages of cheap props?
98srx6
Re: How are the cheap props here on iboats?
I'm not sure what you mean by "cheap props" but if you do a search on here for the different brand names, you will find a wealth of information. One thing that is for sure is that the advantages and disadvantages of a prop on any given boat is not going to be determined by the cost of the prop. Believe it or not, some of us choose not to use a stainless prop for reasons other than cost...
Fordiesel69
What is mean by "cheap prop" is here on iboats, for the same pitch, same size, same aluminum, some start at $96 and go up to $243. I want to know if there is a problem buying a $96 solas brand. I am unsure why the big price differences.
Now stainless which I am NOT even considering as I already have one, is even more money.
marcortez
I just unboxed a Solas Amita 13 1/4" x 17" aluminum prop today.
The finish is nice, the casting looks first rate, the splines are shiny brass, rubber hub....overall, and without having bolted it on yet, I would say it appears to be a well made prop.
Made in Taiwan China if that is of concern to you.
trendsetter240
The Solas aluminium props are an excellent value prop. I have Solas Amita 4-blade 13p that I use for watersports and a Solas HR Titan 4-blade 15p stainless that I use as my main prop.
Fordiesel69
As with everything today price is everything. Just making sure I was not buying a prop that would leave me stranded because I was being a cheapskate. In my opinion a hub should never spin unless the prop got struck. Although my buddy said he had his spin and never hit it on anything. That is actually my biggest fear is a hub spin for no reason.
hwsiii
Ford, this might give you an indication of the quality of the Solas props.
Solas Squeeze Casting
H
180shabah
ford - solas isone of the big players in the prop market, quality will not be a concern. Just make sure you are chosing the CORRECT design and pitch, not just a price.
180shabah
Just went back and looked at your siggie - You may want to take a look at the Turning Point Legacy/Hustler props, they have a very aggressive blade design and are ventilated to help with hole shot.
Fordiesel69
Will this work here:
http://boatpropellers.iboats.com/Me...18306/?**********=187242270&*******=529235560
looking at my boat in the signature? It will run up to about 4300RPM now wide open and I can match my rpm to MPH using the in boat guages. So at 3100 RPM I am going about 31-33 MPH for the most part. I have a 21 pitch on there now in stainless.
Price is really an issue because I will damage it for sure, not to mention spent money on lots of other things lately. I am a newbie. And will be doing alot of boating without a depth finder.
Fordiesel69
My funds are alotted to other things this year. I blew my chance to buy one over the winter. The one on the boat is not functional.
Anyways back to the prop. Will that work?
trendsetter240
Yes, that one will work. If I were in your shoes I would go with a 4-blade 19p to raise your RPM at WOT up to 4800 and improve hole shot and water sports.
This one: http://boatpropellers.iboats.com/Me...0-Pitch_Amita_1513-143-19_Propeller/767/9566/
The turning point hustler is also a good option. I would go with a 19p in that one also.
Fordiesel69
21" vs 19" pitch will do what for fuel economy? Any idea if a 19 is what is supposed to be on a 5.0L. For some reason I beleive somone upped it. I have no basis for this assumption, thus why I am asking.
trendsetter240
It's about getting the prop that will allow your motor to turn at the top end of the manufacturer's recomended RPM range at WOT. If the 21p only allows 4300RPM at WOT and the 19p allows 4600-4800 then the 19p is the better choice.
Running an over pitch prop may result in slightly better fuel economy but will cause more wear on the engine because it is working harder to turn the prop. Over propping increases operating temperatures and carbon buildup.
Fordiesel69
My merc owners & maint manual that came with the boat, says 4200RPM - 4600RPM. I am also going by my boat tach not a precise one.
Going to a 19p prop will do what? Raise RPM, cut top speed slightlt, cut fuel economy slightly, but gain engine life, and improve take offs. Am I correct?
Mtypically what do people run on the 5.0L 200HP engines with 19-20' boats?
hwsiii
Ford, if you will give us your exact WOT RPM and speed we can help you make a more educated decision.
H
180shabah
Typically a boat in that size range with a v8 will run a 17" or 19" or 21" or 23" prop. Mostly the middle two, but........
If you can get EXACT WOT numbers and include the gear ratio in your drive (probably 1.6ish) then we can help you get the correct prop for YOUR boat.
Fordiesel69
Can a S/N tell you the gear ratio? GPS says 51 MPH at 4300 RPM, I do not have a more precise instrument for rpm. Boat speedo shows 56 at 4300 rpm. All the boats I test drive, the GPS is always at least 5 under the speedo reading. Must have something to do with the pickup tubes.
cougar1985
i have a solas amita four blade and i can tell you i absolutly love it!also have the michigan wheel ones with the new style hubs and their pretty slick also!luckly for me my friend is a prop repair guy and retailer so i get to try several types till i find what i and my motor like.
