nola mike
- Apr 22, 2009
- 5,682
Ok, I didn't even know about the "quirks" of this engine until recently, and I have some idea of the responses that i'll get to this, but I've read a lot about it here and on other forums. Despite the negative rep, I'm still considering buying a boat with one of these. Reason being, in the price range i'm looking at, I think i may be better off taking my chance on a boat/motor that has been obviously well taken care of/maintained than on a more 'reliable' powerplant which has been more abused. Anyway, I want a clear idea of what i'm getting into. The major issues that i've seen with this engine, at the end of the day don't seem like a big deal. Seems like this wasn't merc's finest design effort, but i'm still not convinced that it's a deal-breaker, if all else is right.
1. Charging system. ok, it sucks. Seems like an easy/not too expensive fix to retrofit an alternator.
2. Cooling system: Again, it sounds like the cooling issues are not as pronounced with an upgraded heat exchanger (when did the 4" become standard?), which is pricey to upgrade, but again, not insurmountable.
3. Cam shaft seal: This seems like the worst and priciest failure point. I haven't been able to get a good handle on what this costs in terms of time/money for a diy'er. Seems like the engine can stay in to do the work if there's room in the front to work, but the one guide I saw called for special tools costing $500 or so. Looks like i should look for a coolant leak at the front of the engine (somewhere?) to assess.
4. Parts availability: Which parts in particular are we talking about?
5. Lastly, should the engine need to be rebuilt, it seems like it would be better to replace it with a more traditional engine. I've seen some info on needing to mod motor mounts, but again, i'm not sure about the difficulty involved in this. For my application (~19' bowrider), a 4.3L seems like the best replacement.
What else am i missing?
