how big of a winch do i need?
Bob427
18' starcraft holiday dry wieght new 900lbs
outboards 400lbs
plus gas and gear i'm thinking another 500lbs
grand total of 1800lbs
what size winch to get safe to say 2000lbs would do?
thanks
NYBo
Re: how big of a winch do i need?
A 1200#-capacity winch will be fine. You're dragging the boat onto the trailer, not lifting it.
tpenfield
Are we lifting this straight up, or just putting it back on the trailer?
I have a 1600 lb winch for my 5,000 boat
smokeonthewater
yes a 2000 lb winch would be safe... smaller would work fine too but it NEVER hurts to go bigger on a winch.
Bob427
just for pulling the boat back up on the trailer
dingbat
Winch ratings are very misleading. They give you the “capacity” of the unit but don’t give you the amount of “input” (your shoulder) required to produce that capacity so the question comes down to how shoulder do you want to put in it?
When comparing winches, divide the stated capacity by the gear ratio then multiply by the load correction factor(actual load/winch capacity). This will give you a idea of how much shoulder you’ll need to put into it.
Here are some examples from the Iboats website.
1800/5 = 360 x 1 = 360
2000/4 = 500 x 0.9 = 450
2000/9.8 = 204 x 0.9 = 183
2600/12.1 = 214 x 0.7 = 150
The #2600 unit will require less half as much shoulder to produce the same pull as the #1800 unit.
outboards 400lbs
thanks
Ayuh,.... Any of the winches listed on iboats will work, even the 600lb.ers....
As noted, yer only draggin' the hull up the wagon, Not clear liftin' it...
