Re: How can i check to see if tilt/trim works?
OK, You need to jumper the solenoids that power the trim/tilt motor. If that motor has a PTT unit that fits between the transom brackets, the solenoids are mounted under the motor cowling. If that motor has the trim pump in the boat, the solenoids are mounted on the trim motor bracket. Each trim solenoid will have a heavy battery cable, and heavy power cable that runs to the trim motor, and a thinner wire colored blue/white or green/white. Jumper from the red battery cable to the blue/white wire and the motor should trim up. jumper from the red battery cable to the green/white wire and the motor should trim down.
