How can I find out the gear ratio of my lower unit? '86 70hp Evinrude
Larry3215
Im just starting the process of trying to fine tune the prop for my 1986, 70 hp Evinrude E70ELCDC.
I think it has the large gear case, its 4 1/6" diameter, but it has a 13 spline prop shaft.
How can I figure out what my gear ratio is to use in the prop calc programs?
Thanks in advance!
Larry
emdsapmgr
Re: How can I find out the gear ratio of my lower unit? '86 70hp Evinrude
The 3 cyl engines had two gearcase gearsets that year. The 75 gearset was 15:28 (.536). All other consumer models used 12:29 (.414)
Faztbullet
The 20" 60,65,65C,70 and 75 have the same gear ratio(12:29) only the 15" motor is different as its the small gear case.
Larry3215
Thanks guys!
Where do you find this info? Ive tried looking up the gear sets at several on-line places, but never could find out the tooth counts to figure it out.
emdsapmgr
They are listed in the 1986 Evinrude sales brochure. Probably in the factory service manual also.
Larry3215
Thanks!
