How do I change the title of my thread?
Mikeopsycho
My project got bigger and I should change the title of my thread, how do I do this?
Thanks, Mike
Fun Times
Title Test change!
Title Test change!
Hi Mike, To change the title all you should need to do is click on "Edit Post" then click on "Go Advanced", Click on the Title Area and input what you want it to say.
Hope this helps, Good luck.:)
Mikeopsycho
Re: How do I change the title of my thread?
Hi Fun Times, I tried it on this post (corrected spelling) and it worked. Thanks for the reply.
Mikeopsycho
Hmmmm....I tried this on my thread and it only changes the title on the post itself, not the title of the entire thread, which is what I'd like to do. I tried it on the last and on the first posts, the thread still has the original title. Can this be changed as well?
Fun Times
The other ones can only be done by a forum moderator .
The first one changed will show on the main home page.
Mikeopsycho
OK, would you be able to change it for me? What info would you need to make the changes?
The original thread is titled "1979 26' Commander water tank replacement". Because the scope of my project has increased I'd like to retitle it "1979 26' Commander gas & H2O tank replacement & ?"
Thanks,
Mike
Mikeopsycho
wooops
WIMUSKY
Done, Mike........
WIMUSKY
Mikeopsycho
Thanks WIMUSKY.
