Re: How do I check "spark" under power.
thanks to all.
A simple check with a spark gap tester showed that top cylinder had no spark at all. After switching cable and spark plug with lowe cylinder no change. Mast be the coil. Will try swapping the coil tomorrow and cleaning grounding terminals that are corroded.
What confused me is that on the river when unplugging wires one by one, every cylinder contibuted, hence though that it only did that under load.
